AUTODATA 3,45
VW/Audi/Škoda/Seat
1NIO1
AUTODATA 3,45
Příspěvek od 1NIO1 »
johnyd1
Re: AUTODATA 3,45
Příspěvek od johnyd1 »
Koleos 2018
Intens Energy dCi 175 4x4
-Can-clip,Vag-VCDS-OP-com-Fiat EcuScanKts 540 Esi2 Bmw ista-d
1NIO1
Asi 2,2GB. a uz sem zkoušel i na W764 i 32. Vse probehne ok.
Ostatni vereze vzdy v poho.ted nemuzu prijit na to co je spatne.
Nejspise 64bit verze a 32nechci preinstalovavat.- /mnoho autoprogramu a diagnostik/
1. Run "Install_x86" or "Install_x64" depending on your OS (32 or 64 bit)
2. Follow on console screen messages and wait for the installation to complete
* Windows 7/8/8.1/10 users MUST do following "a-i" steps while XP users should skip to step 3 *
a) Disable UAC
b) Restart/Reboot your PC
c) Disable Antivirus because the next step is false-positive (NOT virus)
d) Run "dseo13b.exe" as Administrator (<<< this is important) - Enable Test Mode
e) Restart/Reboot your PC (after restart/reboot "Test Mode" will be shown on screen)
f) Disable Antivirus again
g) Run "dseo13b.exe" as Administrator (<<< this is important) - Sign a System File
It's best to find your own path but depending on your OS it should be:
32 bit = C:\Program Files\nodongle.biz\AuDaS0\AuDaS0.sys
64 bit = C:\Program Files (x86)\nodongle.biz\AuDaS0\AuDaS0.sys
...and wait for confirmation message
h) Exit from DSEO (dseo13b.exe)
i) Restart/Reboot your PC (those "a-i" steps are for signing emulator, NOT needed for XP)
3) Open "Keygen" folder and Run "GetUid-x86" or "GetUid-x64" as Administrator (<<< this is important) depending on your OS (32 or 64 bit)
4) Now because you have your UID number you can run "keygen.cmd" and paste/enter it to generate "license.reg" registry file (it's important to NOT enter first 2 digits which are probably 64, enter ONLY last 8 digits)
(in case your UID is 6400000000 you must restart/reboot your PC and go back to step 3 because that UID is NOT proper and valid)
5) Run new generated registry file named "license.reg"
6) Start Emulator as Administrator (<<< this is important) from Start menu or from installed directory which is probably something like C:\Program Files\nodongle.biz\AuDaS0 and there is a file named "ndStart.cmd" or "ndRestart.cmd"
7) Open "Autodata 3.45" from desktop shortcut or ofcourse C:\ADCDA2\ADBCD.exe
(Any kind of errors related to NOT successfully registered .reg files? Just register them manually from "RegSettings" folder as described at the beginning of this text (before all this steps))
8) Enjoy!
octaviask
Příspěvek od octaviask »
idem to skusit, co ti na tom nejde?
Čert
Příspěvek od Čert »
Je to verze 3.44 ENG
Naposledy upravil(a) Čert dne 30 pro 2016, 20:44, celkem upraveno 1 x.
Čert
Příspěvek od Čert »
Na Win7 se to povedlo rozchodit.
Na XP to končí hláškou první nebo druhou.
dury2
Příspěvek od dury2 »
zkouším to dostat na XP s jednojádrem, ale v adresáři keygen nemám složku GetUid-x86.exe.
Nemá to někdo. díky
yary1
Příspěvek od yary1 »
uloz.to/!Tug2cNXfCHzq/getuid-x86-rar
Nepanikarim,v tichosti prihlizim.
dury2
díky, ale nejde mi to stáhnout:
:\Users\STOLN-~1\AppData\Local\Temp\oGxYQXny.rar.part nemohl být uložen, protože nemohl být přečten zdrojový soubor.
Zkuste to prosím za chvíli znovu nebo kontaktujte administrátora serveru.
yary1
Problem je ulozto oznacuje to jako malwarko.
zkus toto ,je tam 86*64*lic.
uloz.to/!XljziD09vrRw/20161230-235853-iso
dury2
Díky za ochotu, každopádně ted to píše že byl soubor smazán.
Mohl by jsi prosím ten samotný soubor třeba zabalit a dát to tam ještě jednou? Díky moc
yary1
filedropper.com/info_2
ufile.io/d9106
dury2
díky mám, ale potřebuji obsah složky keygen, přesněji:
3) Otevřete složku "Keygen" and Run "GetUid-x86" nebo "GetUid-x64" jako administrátor (<<< to je důležité) v závislosti na vašem operačním systému (32 nebo 64 bit)
nemám právě ten soubor getUid-x86 -potřebuji to zkusit na jednojádru. Díky
Čert
Příspěvek od Čert »
Soubor i příponu přejmenuji, zabalím do zipu a stejně to
antivirák označí jako nechtěnou havěť.
Nevím jak poslat...
dury2
emajl
D
