[b]JAK VYROBIT VYSOCE UČINNÝ VODNÍ OHŘÍVAČ OLEJE (NEREZOVÝ K
jbclaudio
Příspěvek od jbclaudio »
(rofl)
PODAŘILO SE MI VYROBIT VYSOCE UČINNÝ VODNÍ OHŘÍVAČ OLEJE TAK MOŽNÁ NĚKOMU BUDE INSPIRACÍ A POMUŽE VYŘEŠIT JEHO PROBLÉM.
KOUPIL JSEM NEREZOVÝ INSTALATERSKÝ KRK 4m KDE MI PŘÍMO V PRODEJNĚ NALISOVALI NA KONCE MATICE NA KTERE SE NAMONTUJE REDUKCE NA GUMOVOU HADICI DLE LIBOVOLNEHO PRŮMĚRU.KRK JE VYROBEN Z NAPROSTO TENKÉHO NEREZOVÉHO PLECHU CCA 0,2MM STĚNA.ŽEBROVANÍ KRKU ZARUČUJE JEŠTĚ VELKOU PLOCHU NA PŘENOS TEPLA.
KRK VELMI PEČLIVĚ SVINETE DO SPIRÁLY A TEN PŘIJDE VLOŽIT DO OPLAŠTĚNÍ.
OPLAŠTĚNÍ:ČERNÝ PLECH,VYSTŘIHNOUT DVĚ KOLA O PRŮMĚRU 230MM A MEZI KOLA PO OBVODU NAVAŘIT ŽELEZ.PROUŽEK O ŠÍŘCE 20MM.NEZAPOMENOUT NAVAŘIT DVĚ TRUBKY NA VODU Z TOPENÍ.PRŮMĚR ZVOLIT PODLE VAŠÍ HADICE NA KTEROU SE BUDETE NAPOJOVAT.TRUBKY NAKLONIT DLE VAŠEHO UVÁŽENÍ ABY VODA IDEALNĚ PROUDILA A PŘEDÁVALA TEPLO.
VYŘEZAT PRVNÍ OTVOR NA OBVODOVEM 20MM PROUŽKU OTVOR NA NEREZOVÝ KRK.
DALŠÍ DIRU V DRUHÉM JEŠTĚ NEPŘIVAŘENÉM KOLE PROVRTAT PŘÍMO VE STŘEDU KOLA .VLOŽIT SVINUTÝ KRK A PROVLEST VÝVODY Z OPLÁŠTĚNI.TADY VYVÉST KONEC KRKU.ZAVAŘIT KOLO A ZALETOVAT NEREZOVÉ TRUBKY KRKU.KONEC
PRO CO NEJRYCHLEJŠÍ OHŘÁTÍ OLEJE DO ČERPADLA VLOŽIT DVA KRKY DO JEDNOHO OBALU.JEDEN KRK BUDE ZA FILTREM ABYCHOM NEMUSELI ČEKAT AŽ NAHŘEJEM VELKÉ MNOŽSVÍ OLEJE VE FILTRU.
DRUHÝM KRKEM OHŘÍVAT OLEJ KTERÝ POTEČE DO PALIVOVÉHO FILTRU.
DÉLKA DVOU KRKU JE 2* 4METRY.
ŠÍŘKA OBVODOVÉHO PROUŽKU PRO DVA KRKY JE 35MM.
NAPOJENI VODY PROVÉST PLASTOVYM ( T ) "TÉ" KUSEM POUŽÍVANY VE FIRMACH MONTÁŽÍ PLG CENA JEDNOHO JE 19,-KČ
CENA KRKU ZA METR 119,-KČ
OBAL OHŘÍVAČE JE JEŠTĚ TŘEBA DŮKADNĚ ZAIZOLOVAT I POTRUDI.
NA MATKU KRKU JSEM PŘIDAL ČIDLO DIG. TEPLOMĚRU ZA150,- ABYCH VĚDĚL KDY TEPLOTA PŘEKROČÍ HRANICI 70 STUP.(MAX.HODNOTA TEPLOMĚRU).
VLOŽÍM VÁM I NĚJAKÉ FOTO JEN MI MUSÍTE PORADIT JAK. AHOJ JIRKA
ČLAN.ZATÍM BEZ KOREKCÍ SORRY (offtopic) (wallbash)
ROVER 220 tdi 77kW r.v.1999 HONDA MOTOR
JEZDÍM NA POUŽITY FRIT OLEJ.
jbclaudio
nevím jak vložit foto poradítemi.díky
Tkevlar
Příspěvek od Tkevlar »
Ahoj. Zajímave.
Foto musísš mít už někde na internetu. Potom kliknes na IMG. A mezi to vložíš odkaz kde je foto.
Foto muzes vlozit na image http://www.imageshack.us/
AR 155 1.8TS
ex. Fiat Tipo 1.7D
bertold
Promiň...
Příspěvek od bertold »
som zo "reformovaného" Slovenska a neviem si prelozit český výraz
"instaletérsky krk".Môžes mi "polopatisticky" vysvetlit o co ide?.Tato tema ma mirodiadne zaujima a uz dlhsiu dobu si lámem hlavu ako vyrobit ucinný výmennik voda - olej.Dakujem.
Ford Transit 300S,mikrobus,2.0Tdi,100k,Duratorq 16V.
Najazdených cca 50000km na R.O,predohrev "homemade" cca 200cm2.dvojnadrzovy...Vstrekovacie č. BOSCH
bobyd
Příspěvek od bobyd »
chce to fotky jestli dobre chapu tak krky maj prumer 2 cm?
jinak krk jestli myslim z eje to co mysim je takova hrbolata hadice kterou elektrikari perou do zdi a protahujou jima draty
Sharan 1.9 TDI 96 kw GOAL
OVCE 2.0 TDI 103 kw BKD
JanCI
Příspěvek od JanCI »
nie si z juzneho SVK?
instalatersky krk je to iste aj v slovencine
to je ako keby rovna rura,kt ked chytis mozes ohybat ako xces preto sa to vola krk
Radim205D
Příspěvek od Radim205D »
tak jsem si dal tu praci a hledal jsem a myslim ze to byla docela fuska neco najit
http://www.maflex.cz/CZ/Kestak/MainPage.htm
E91 N52B30 :)
Radim205D
E91 N52B30 :)
jbclaudio
krk má vnější průměr 12mm a vnitřní 8mm.
JINAK RADIM NAŠEL JEDNOHO Z MNOHA VÝROBCŮ TĚCHTO HADIC.
JEN KAŽDÝ MUSÍ OSLOVIT SVŮJ DOSTUPNÝ INTALATERSVÍ (VODA-TOPENÍ)OBCHOD A VYBRAT TEN SPRAVNÝ PRŮMĚR.JA ZVOLIL CO NEJTENČÍ.
ŠÍŘKA OHŘÍVAČE TEDY ŽELEZNÉHO PROUŽKU KTERÝ ZAVAŘÍM NA OBVOD PLECHOVÝCH KOL PRO JEDNU HADICI JE 20MM A KDYŽ BYCH CHTĚL DVĚ POTRUBÍ NA OHŘEV PŘED FILTREM A ZA FILTREM.ŠÍŘKA JE 35MM.
DÍKY ZA REAKCE !!!!
NAPIŠTE SVŮJ NÁZOR ABY FORUM BYLO FOREM.
Radim205D
to jbclaudio: pises "JINAK RADIM NAŠEL JEDNOHO Z MNOHA VÝROBCŮ TĚCHTO HADIC" posli prosim link na nejakeho ceskeho vyrobce ja jsem horkotezko nasel tento produkt a to jeste na strankach prodejce :?
E91 N52B30 :)
Radim205D
a co se tyce meho nazoru aby tak ja pises bylo forum forem ;) naklady na vyrobu a pracnost nemaj daleko od uvahy nakupu deskoveho vymeniku v cene kolem 1000,- viz. http://www.secespol.cz/Catlists/Lline/LA14.pdf
E91 N52B30 :)
Radim205D
to jbcl: posli mi fotky tveho vymeniku na mail a ja ti to pres svuj server sem soupnu jako link
hdesign@seznam.cz
E91 N52B30 :)
Radim205D
jinak pro motivaci ,ja pouzivam k mereni teplot modre podsviceny monitorovaci panel pro pocitacovou skrin s 3 cidly napajeni je 12V
http://www.czechcomputer.cz/product.jsp?artno=26812
ceny u prodejcu PC jsou ruzne okolo 250 az 300,- ja jej koupil za 230,- :)
E91 N52B30 :)
bertold
Vďaka
Pochopil som a svoje vysledky v tomto "obore" zverejnim i fofo.
Velmi dobry napad...Gratulujem.Lebo toto je alfa i omega a povedal by som,ze najdôlezitejsia cast prestavby - poriadny vymennnik kôli viskozite a kvoli dobremu rozpraseniu paliva,aby sa nedostavalo do motoroveho oleja tym ho neznehodnocovalo - kontaminovalo.Dikes
bobyd
je pravda ze pro mene zrucne jako jsem ja lze pouzit i tyhle bazmeky na klimatizaci a zavarit pouze jednu stranu uz se mi to zacina rysovat
http://www.d-klima.cz/katalog_4.htm
