Nejde nakódovať modul xenonu PASSAT 3C rok 2006 7L6941330
MONTI
Příspěvek od MONTI »
Vag píše toto:
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000001
Shop #: WSC 05311 000 08193
VCID: F1ED53D2E8B2BB1
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: ID-R fehlt
Component: AFS-Lst.-Modul r ....
Coding: 00000255
6 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 27
Reset counter: 86
Mileage: 177353 km
Time Indication: 0
Date: 2012.07.13
Time: 16:31:13
02233 - Left Headlight Power Output Stage (J667)
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 177353 km
Time Indication: 0
Date: 2012.07.13
Time: 17:04:16
Modul je nový,obj.číslo 7L6941330...Starý modul mal kodovanie 0000035.Používam postup :
spojím s 55-Xenon, bezpeč.prístup 15284,kodovanie,vyberem Subsystem 2 - Part No: ID-R fehlt ,povodne kodovanie 0000255,prepísem na 0000035 a error.....Nejde to prepísať.....Podporuje VAG takuto funkciu,alebo len VAS,podprípade len online v autorizáku???
Mato86
Příspěvek od Mato86 »
Nemalo by sa tam robiť základné nastavenie?
Passat 3C variant 2,0tdi BMP
VAG CAN PRO,K+CAN Commander,Delphi uni diag. VAGPROG
MONTI
Mato86 píše:Nemalo by sa tam robiť základné nastavenie?
Základné nastavenie nejde pokial nie je nakodovaná,ani prispôsobenie....
dhfool
Příspěvek od dhfool »
Ulož tam znovu 0000001, vypni a zapni klíček.
Škoda Superb II 1.8 TSI DSG-7
SuperVAG Comfort VW/PSA 2017
BMW DIS/GT1 v57 /ISTA D
