passat netahne
passat netahne
Zdravim,prosim o radu.Koupil jsem passata jiz predelaneho z automatu na manual,ale mprijde mi ze je auto line,citelny zaber turba je cca od 2200-2800 a pak zase téměř nejede.... je tato RJ 3B0907401H na automat nebo manual?Na polodotu mam stále znaceni automatu.Dik za rady.Jedna se o motor AFB 2.5tdi 110Kw.
tak jsem delal log,je to první tak snad spravne.
Friday,31,May,2013,17:14:47
3B0 907 401 H ,,0000AG D65 ,
,Group A:,'004,,,,Group B:,'003,,,,Group C:,'010
,,otáčky,Bod zážehu,Bod zážehu,Poměr sepnutí,,otáčky,Vzduch/zdvih,Vzduch/zdvih,Poměr sepnutí,,Vzduch/zdvih,Absolut.tlak,Absolut.tlak,zátěž
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min,°,°, %,STAMP, /min, mg/R, mg/R, %,STAMP, mg/R, mbar, mbar,%
,0.37,1183,6.4,0.8,100.2,0.77,1206,859.6,408.2,95.5,0.01,380.7,959,938,0.0
,1.55,1299,5.0,4.4,73.8,1.95,1369,859.6,447.5,95.5,1.17,431.8,959,1030,100.0
,2.75,1508,4.0,3.2,73.8,3.15,1601,859.6,549.5,95.5,2.33,467.1,959,1193,100.0
,3.94,1786,4.0,4.2,77.7,4.34,1879,871.4,718.3,95.5,3.55,604.5,959,1499,100.0
,5.16,2088,4.2,3.8,71.4,5.57,2204,879.2,655.5,95.5,4.74,573.1,959,1652,100.0
,6.39,2413,4.8,5.0,65.1,6.79,2529,879.2,730.1,95.5,5.97,690.8,959,1754,100.0
,7.59,2691,4.4,4.8,65.1,7.99,2738,879.2,734.0,95.5,7.19,706.5,959,1877,100.0
,8.77,2877,5.6,5.4,62.7,9.17,2923,879.2,777.2,95.5,8.38,753.6,959,1989,100.0
,9.97,3016,6.6,6.4,59.6,10.35,3062,879.2,792.9,95.5,9.57,785.0,959,2101,100.0
,11.15,3178,7.0,7.2,58.8,11.55,3225,879.2,749.7,95.5,10.75,788.9,959,2162,100.0
,12.35,3318,7.4,7.6,56.8,12.74,3364,879.2,745.8,95.5,11.95,737.9,959,2040,100.0
,13.54,3457,8.0,8.0,56.0,13.93,3503,879.2,745.8,95.5,13.14,745.8,959,2091,100.0
,14.73,3596,8.4,8.4,52.5,15.12,3619,879.2,734.0,95.5,14.33,741.8,959,2132,100.0
,15.92,3735,9.0,9.4,51.3,16.32,3782,879.2,714.4,95.5,15.52,726.1,959,2142,100.0
,17.11,3851,9.4,9.8,50.9,17.50,3898,879.2,694.7,95.5,16.71,706.5,959,2132,100.0
,243.14,766,-1.0,1.8,100.2,243.54,766,274.8,384.7,15.0,242.74,392.5,959,979,0.0
,244.33,766,-1.0,1.8,100.2,244.73,766,278.7,384.7,15.0,243.94,384.7,959,979,0.0
,245.52,766,-1.0,1.8,100.2,245.92,766,282.6,384.7,15.0,245.12,392.5,959,979,0.0
,246.71,766,-1.0,1.8,100.2,247.11,766,278.7,388.6,15.0,246.32,388.6,959,979,0.0
,247.93,766,-1.0,1.6,100.2,248.34,766,278.7,388.6,15.0,247.53,384.7,959,979,0.0
Nn myslim povstrik,pac jsem se tu docetl,ze si pry pedvstrik ridi cerpadlo samo.Tady je ten LOG http://ulozto.cz/xxViDwU8/passat-pavel-csv
Re: passat netahne
Ja by som si stoho moc hlavu nerobil, 2,5 110kw hovno taha aj od novoty. zaber co pises je tiez vnorme, ono po 2300 vykon necakaj.piny89 píše:Zdravim,prosim o radu.Koupil jsem passata jiz predelaneho z automatu na manual,ale mprijde mi ze je auto line,citelny zaber turba je cca od 2200-2800 a pak zase téměř nejede.... je tato RJ 3B0907401H na automat nebo manual?Na polodotu mam stále znaceni automatu.Dik za rady.Jedna se o motor AFB 2.5tdi 110Kw.
Bud rad ze to auto po uprave drzi pohromade a cerpadlo este stale spricuje...
A radsej ani nechcem videt vypise ostatnych riadiacek, lebo urcite sa s elektrikou asi nikto moc nezapodielal. viz. automatika na dote.
Passat V6 bdh 180hp 4motion Chip by Kitpower.fr 206hp, Chip by Dynatec.fr 218hp
