Budiky Passat B6 103KW
Miki2t
Příspěvek od Miki2t »
Passat B6, budiky zdechli uplne jak odpojeny,auto jede (immo v nich asi neni). Nemáte nekdo pinout prosim ?
Cilo budiku je 3C0920860H.
v konektoru na strane auta jesme nameril: pin19 GND, pin2 30, pin1 15.
Potrebuji zjistit jestli jsou spatne budiky nebo je problem mimo.
Jirka.
Příspěvek od Jirka. »
Dash panel insert -K- / Control unit in dash panel insert -J285-
36-pin connector -T36- :
N97-10281
1 - Terminal 15 voltage supply
2 - Terminal 30 voltage supply
3 - Not assigned
4 - Not assigned
5 - Brake fluid level warning lamp
6 - Warning lamp for electric parking brake and handbrake
7 - Not assigned
8 - Not assigned
9 - Not assigned
10 - Not assigned
11 - Not assigned
12 - Diagnostic interface for dash panel CAN data bus, low
13 - Diagnostic interface for dash panel CAN data bus, high
14 - Dash panel CAN screening
15 - Dash panel CAN wake-up wire
16 - Fuel gauge sender (full), only with all-wheel drive
17 - Fuel gauge sender (full)
18 - Fuel gauge sender (empty)
19 - Terminal 31
20 - Not assigned
21 - Not assigned
22 - Front left brake pad wear sender
23 - Fuel gauge sender (empty), only with all-wheel drive
24 - Not assigned
25 - Oil pressure warning lamp
26 - Oil level and oil temperature sender
27 - Not assigned
28 - Speed signal, sliding sunroof adjustment control unit output, control unit with display for radio and navigation system
29 - Not assigned
30 - Not assigned
31 - Not assigned
32 - Not assigned
33 - Terminal 31, sensor earth
34 - Washer fluid level warning lamp
35 - Coolant temperature and coolant shortage warning lamp
36 - Ambient temperature sensor
Jirka.
Kdyžtak mám diesel rovnou s maxidotem za 1500 kč případně polodot za 700kč
a imo v nich opravdu není
Miki2t
Dekuji,
Když piny 1,2,19 jsou spravne, jsou mrtve budiky ?
anydraj
Příspěvek od anydraj »
Pokud mas napajeni 1-2 a 19 GND spravne, tak jsou KO.
Immo je v komfortnim modulu za prihradkou spolujezdce.
stanomx
Příspěvek od stanomx »
nazdar skapali mi budiky 3C0 920 852 J
mam ich na stole pozeram ci nieco neuvidim
neopravoval to uz niekto?
pripadne ake nahrady mozem pouzit?
tieto nemaju palubny pc tak by som uz namontoval nejake s pc
vďaka
Jirka.
Mám s maxidotem nafta 1200Kč
