Peugeot Laser 6.5.0/AP1u 1/2006
ipo Boss
Příspěvek od ipo Boss »
Kód: Vybrat vše
1. Burn the imagefile PeugeotLaserCD.nrg to a CD
2. Burn the imagefile PeugeotLaserDVD.nrg to a DVD,
   Use Nero 7 to do that. (or whatever burning promgram you are using.)
3. Copy the diskettfiles to a newformatted 3,5"
4. Unzip the Label.zip with winzip.
   There you will find labels for CD and DVD and a cover for the DVD-box.
5. Put the 3.5 in the floppy and do not remove it during the installation.
6. Put the CD INSTALL in your DVD reader and begin the installation
7. When asked
   Number of subscription: 66647062726B70-95
   Password Admin: TOTOT
8. When Installation is done put the DVD in the reader
   and execute ?=Drive [?]:/APP/LASER/BIN/LASER32.EXE
   The installation will not work if you have more than one HD and one DVD !
   During the you will be asked if you will keep files 4-10 times
   depending on your operating system language. You have to answer YES each time.
   The program has a very long startup time! more than 5 minutes on a P4 3,0 Ghz !!!!
   When using the program for the first time you can choose whatever language
   you prefer, All EU-Language is included.
   During installation you can only use English and French.
   Happy Surfin' :-)
INSTAL CD:
Kód: Vybrat vše
http://rapidshare.com/files/49297229/PeugeotLaserCD.part1.rar
http://rapidshare.com/files/49303605/PeugeotLaserCD.part2.rar
DATA DVD:
Kód: Vybrat vše
http://rapidshare.com/files/50589018/PeugeotLaserDVD.part01.rar
http://rapidshare.com/files/50497781/PeugeotLaserDVD.part02.rar
http://rapidshare.com/files/50506168/PeugeotLaserDVD.part03.rar
http://rapidshare.com/files/50515878/PeugeotLaserDVD.part04.rar
http://rapidshare.com/files/50526590/PeugeotLaserDVD.part05.rar
http://rapidshare.com/files/50537786/PeugeotLaserDVD.part06.rar
http://rapidshare.com/files/50549926/PeugeotLaserDVD.part07.rar
http://rapidshare.com/files/50562083/PeugeotLaserDVD.part08.rar
http://rapidshare.com/files/50573774/PeugeotLaserDVD.part09.rar
http://rapidshare.com/files/50712972/PeugeotLaserDVD.part10.rar
http://rapidshare.com/files/50724032/PeugeotLaserDVD.part11.rar
http://rapidshare.com/files/50736250/PeugeotLaserDVD.part12.rar
http://rapidshare.com/files/50748811/PeugeotLaserDVD.part13.rar
http://rapidshare.com/files/50601563/PeugeotLaserDVD.part14.rar
http://rapidshare.com/files/50759314/PeugeotLaserDVD.part15.rar
http://rapidshare.com/files/50771365/PeugeotLaserDVD.part16.rar
http://rapidshare.com/files/50783923/PeugeotLaserDVD.part17.rar
http://rapidshare.com/files/50804886/PeugeotLaserDVD.part18.rar
http://rapidshare.com/files/50816936/PeugeotLaserDVD.part19.rar
http://rapidshare.com/files/50828886/PeugeotLaserDVD.part20.rar
http://rapidshare.com/files/50842160/PeugeotLaserDVD.part21.rar
http://rapidshare.com/files/51551190/PeugeotLaserDVD.part22.rar
http://rapidshare.com/files/51560207/PeugeotLaserDVD.part23.rar
http://rapidshare.com/files/51570022/PeugeotLaserDVD.part24.rar
http://rapidshare.com/files/51582075/PeugeotLaserDVD.part25.rar
http://rapidshare.com/files/51611952/PeugeotLaserDVD.part26.rar
http://rapidshare.com/files/51617737/PeugeotLaserDVD.part27.rar
3.5-DISKETT:
Kód: Vybrat vše
http://rapidshare.com/files/49313342/3.5-diskett.rar
ipo Boss
Upload dokončený :wink:
P.TAZZ
Příspěvek od P.TAZZ »
Jak to mam rozchodit,když nemam disketovou mekániku? :(
Žeru krávy, chráním jetel.
Passat Variant TDI 81KW AFN
Opel Astra 1.6 CDTi 100KW
SKYPE- ptazz1
Yap
Příspěvek od Yap »
P.TAZZ píše:Jak to mam rozchodit,když nemam disketovou mekániku? :(
co to je disketa? to neznám (LOL) (LOL) (LOL)
Vovlo V40 1.9 TDi 66 kW
P.TAZZ
No mě jde o to že je tam něco o disketě,tak mi jde o to jestli to pujde jenom někam zkopírovat nebo to po mě bude chtít tu disketu v mechanice.
"Copy the diskettfiles to a newformatted 3,5"
http://rapidshare.com/files/49313342/3.5-diskett.rar"
kapiš? :)
SKYPE- ptazz1
ipo Boss
P.TAZZ píše:No mě jde o to že je tam něco o disketě,tak mi jde o to jestli to pujde jenom někam zkopírovat nebo to po mě bude chtít tu disketu v mechanice.
kapiš? :)
To neviem. Ten program neni najnovsi a vtedy ked bol aktualny bola disketova samozrejmost... Budes si musiet pozicat od niekoho externu disketouku co pripojis cez USB.
P.TAZZ
No uvidíme až to sosnu,třeba to zatim dam jenom na desktop a disketu mam (teda jestli to pujde na win98) :-(
díky za info
SKYPE- ptazz1
Mortimer
Laser
Příspěvek od Mortimer »
Pokud nemáš disketovku,musíš použít program Virtual Floppy nebo Floppy Image a namountovat obraz diskety:
Kód: Vybrat vše
http://www.towodo.com/products/floppyimage/
P.TAZZ
Re: Laser
Mortimer píše:Pokud nemáš disketovku,musíš použít program Virtual Floppy nebo Floppy Image a namountovat obraz diskety:
Kód: Vybrat vše
No tak to je super moc ti díky to sem netušil čeče že je i virtual disketa. :o
SKYPE- ptazz1
mirec
Příspěvek od mirec »
skúsal som to nainstalovat, tak ze som mal ext. disket. mechaniku do USB. Stále mi vsak pisalo ze disketa v mechanike nie je korektná. Fungovalo to niekomu?
ipo Boss
toto som nasiel na jednom fore
Tak pro vsechny co se s tim teprve budou zabivat
1. Diketa musi byt zformatovana a musi mit nazev LASER_
2. Pokud mate problem s hlaskou "invalid sShortDate" musite jit do registru (START->Spustit->napsat "regedit"->nechat vyhledat "sShortDate"(zmacnout CTRL+F) -> Zmenit na tvar dd.MM.yyyy (klepnout pravym tlacitkem a dat menit) bude jich tam nekolik tak zmente vsechny staci mackat jen F3 a samo vam je to najde.
Jinak jak uz tady bylo receno muzete se tam dostat i pres Ovladaci panely ->mistni a jazykove nastaveni-> vlastni nastaveni
To me bohuzel neslo a porad mi to hazelo hlasku az jsem se nastval a nasel si to ruskych strankach.
Jinak tam psali o tom ze na XP je potreba menit cas a u 98 datum. Ja jsem radeji zmenil oboje.
u datumu to ma byt sShortDate=dd.MM.yyyy
u casu HH:mm:ss
mirec
vdaka moc. Vyskusam
joe
Příspěvek od joe »
ipo Boss,
ak je to disketa z toho povodneho torrentu, tak ta je nefunkcna.
tu je funkcna.
http://rapidshare.com/files/57502557/key_diskette.rar
ipo Boss
joe píše:ipo Boss,
tu je funkcna.
Akoze nainstalovat mi to islo. isiel som podla toho navodu co som sem daval posledne. len pod vistou mi to nechce slapat. mozne je aj niekde inde problem
Okura
Příspěvek od Okura »
mě to něšlo nainstalovat vubec, hlásí to nějakou hlášku o chybějící jazyku Visula Basic 6 nebo něco takového
