VW Crafter - chybové kódy
Popo
Příspěvek od Popo »
Ahoj,
potřebuji poradit s Craftrem, motor 2.5 TDi, 100 kW. Jedná se o to, že turbo má po přeřazení dlouhý náběh a celkově je auto bez výkonu. Občas se rozblikají kontrolky motoru a žhavení a auto padne do nouzáku. Pomůže vypnout a znova nastartovat motor. Děkuji za pomoc. Na diagnostice to píše tuto řadu chyb:
Address 01: Engine Labels: None
Control Module Part Number: 076 906 022 P HW: 076 906 022 G
Component and/or Version: R5 2,5L EDC A020SG 9022
Software Coding: 0003072
Work Shop Code: WSC 22756 401 81987
VCID: 204F060BF036381EB43-5000
5 Faults Found:
008235 - Control Circuit for Reductant Tank Heating
P202B - 000 - Short to GND - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 756 /min
Speed: 0.0 km/h
Voltage: 14.06 V
Temperature: -10.8°C
Temperature: -5.4°C
Voltage: 0.900 V
Voltage: 1.200 V
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 2730 /min
Speed: 54.0 km/h
Load: 100.0 %
Absolute Pres.: 2295.0 mbar
Absolute Pres.: 1448.4 mbar
Lambda: 82.9 %
Lambda: 3.9 %
008598 - Oxygen (Lambda) Sensor B1 S1
P2196 - 000 - Signal too High (Rich) - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1743 /min
Speed: 80.0 km/h
Lambda: 44.2 %
Mass Air / Rev.: 520.0 mg/str
Voltage: 0.600 V
(no units): 0.01
Voltage: 0.975 V
005762 - Powertrain Data Bus
P1682 - 000 - Implausible Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Torque: 0.0 Nm
Temperature: 82.8°C
Bin. Bits: 00010111
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 735 /min
Speed: 0.0 km/h
Voltage: 13.91 V
Temperature: 198.0°C
Lambda: -4.7 %
Bin. Bits: 00001110
Voltage: 2.280 V
Readiness: 1 4 0 0 0
čím to čteš :?
Popo
Příspěvek od Popo »
VCDS 12.12 :(
