Diagnostika VOLVO volFCR
Mireck
Příspěvek od Mireck »
Skusal to niekto? Aky kabel na to pouzit?
Yap
Příspěvek od Yap »
KKL k VAGu by měl stačit
Vovlo V40 1.9 TDi 66 kW
Mireck
Tak najdem VOLVO vyskusam a dam vediet.
váha
Příspěvek od váha »
no záleží jakou verzi programu máš,jsou buď na KKL kabel nebo na HEX-CAN...dnes sem zkoušle Volvo V70 2,5TDI rv.2000 a nic :roll:
Escalade EXT 6.2 AWD flexfuel
Mireck
Je to starsi verze tak doufam ze bude K line
yary1
Příspěvek od yary1 »
VOL-FCR - DEMO software
To check this software will work with your hardware and car, you can download the demo version below.
Click on the link that matches your hardware
SERIAL interfaces
VAG-COM HEX-USB and HEX-USB_CAN interfaces
FTDI based USB interfaces
mas tam na vyber s techto verzi
Nepanikarim,v tichosti prihlizim.
Mireck
Tato verzia nieje z home stranky je to starsie a nie demo. Dokonca sa neinstaluje iba spusta. V About pise ze ide iba cez com1 port
ABOUT:
Vol-FCR(TM), Fault Code Reader for Volvo (TM) Cars. Version Beta 1.3.06
Copyright cr-diagnostics © 2002, 2003.
Supplied by:
ilexa
PO Box 111
Truro
Cornwall
United Kingdom
TR2 4YF www.onboarddiagnostics.co.uk/volfcr
For technical support:
Tel 0870 7543 827 Mon-Fri 09:00-18:00 (GMT) or Fax 0870 7543 829 Anytime.
e-mail volfcr@onboarddiagnostics.co.uk
This program is designed to read & reset fault codes on Volvo (TM) cars.
The program has no connection with the Volvo Car Corporation.
The program will only work on Comm Port 1.
Some S/V 40 engine functions have not been implemented and are disabled.
No liability can be accepted for use of the program or the information presented.
You may wish to print information from the program, the easiest way to do this is to press the Alt + Print Screen keys to take a snap shot of the screen then press 'Go Back' to stop comms and finally paste the screen into a program such as Wordpad, save the result and print / e-mail as required.
-Scroll Down for more-
On ‘96/’97 850 cars with the 16 way ‘OBDII’ socket, and some other models, some of the control modules use ‘flash’ codes, this program is not designed to work with these modules.
The controls for these have been coloured yellow in the program.
THE USE OF THE FOLLOWING INFORMATION IS ENTIRELY AT THE USERS RISK
To retrieve the flash codes the following procedure can be adopted:
Connect an LED, with the correct polarity, in series with a 1k8 ohm resistor, between pin 16 (+) and pin X, where X is the pin corresponding with the module to be read. Connect a push to make switch between pin X and pins 4 or 5 (-).
The circuit can then be used in the same way as the pre ’96 diagnostic sockets, situated in the engine compartment.
For
Motronic 4.3 or Fenix 5.2, X = 3.
ECC , X = 6, Timer Type 4, X = 9.
Cruise Control, X = 13; 900 & S/V 90 ABS, X = 12 .
mejchi
Příspěvek od mejchi »
http://www.rfsystem.sk/download.html
Link na Pinouty na všetky značky aut. Je to z KTSky... :)
http://www.rfsystem.sk/download/Volvo.pdf
Niečo o tom čo to dokáže... :)
http://www.rfsystem.sk/volvo.html
tu je...Verzia 1.3 by mala chodit z fast KKL COM(možno aj USB :roll: )
PASSAT B5 1,9TDI PD Tiptronic 96ky vstriky+chip
Peete
Příspěvek od Peete »
funguje to s kkl, mam vyzkouseno
Nissan Primera SW 1,9 DCi
mejchi
Peete píše:funguje to s kkl, mam vyzkouseno
COM alebo USB?
milanv
Příspěvek od milanv »
nasiel by sa dobrak kt. by mi poslal fungel verziu na: sapag@post.sk
mam klasicky seriovy KKL kabel.
verzia kt. som stiahol zo stranky www.onboarddiagnostics.co.uk/volfcr asi pred mesiacom sa mi este stale nerozchodila, totiz pri spusteni mi ohlasi okno s autorskymi pravami a tlacitko "Accept" je nestlacitelne.
Naposledy upravil(a) milanv dne 23 dub 2008, 21:20, celkem upraveno 1 x.
Audi A4, to je moje
Peete
mejchi píše:
COM alebo USB?
com
