Skusal uz niekto dolievat Aceton do motora ? Bratranec to skusa liat do kamiona aj do Fordu F150 a usetri mu to podla testovanie 20% cca 300dollarov tyzdenne. Vravi,ze to nemoze poskodit resp.ublizit motoru.
Vsetky tieto tu chemikalie Benzen,petrolej,Xylenol,aceton.isopropyl je mozne taktovat a dosiahnut zvysenie oktanoveho cisla a tym aj zlepsenie spalovania a tym aj vyssi vykon. Dolieva 0.6dcl na 40 litrov.
Vraj injector cleaners ako STP Diesel Fuel Treatment a pod. maju zaklad z ketonatov a aldehydov. Injector cleaner je tiez zalozeny na dimethyl keton=aceton a CH3-CO-CH3 dimethylketon= aceton.
linky
http://peswiki.com/index.php/Directory: ... aris:Umbra
http://www.pureenergysystems.com/news/2 ... 9_Acetone/
http://www.probertencyclopaedia.com/cgi ... e&offset=0
Acetone in Toyota Yaris 1.4 D-4D (2003 spec)
[edit]
Summary
Toyota Yaris 1.4 D-4D (UK Spec) ratio(s) of acetone used 50 millilitre per 45 Litre mileage before 30,000 mileage after 40,000 number of miles tested 10,000 other observations (power, idle, exhaust)
[edit]
Individual Reports
[edit]
January 02, 2006
Toyota Yaris 2003 model D-4D - a very hi-tech 1.4 Litre turbo-intercooled engine that would give 65 mpg using stock diesel fuel. Run the car 20,000 miles before trying acetone mix. Difference is around 50-60 extra miles each tank (I get about 660 miles per 45 Litre tank). Very dramatic increase in acceleration all through rev range. Top speed is 10mph beyond manufacturer's quoted figure (GPS verified). Exceptional performance additive that literally pays for itself and then some. Soon to have engine in for regular service when I hope to have emission levels measured, which I will post for interest. Generally engine behaves like a much larger, smoother unit.
Dolievanie Acetonu do benzinoveho a dieseloveho motora...
kupim nove auto a mam to vsetko v pici....
kto vie aky je skutocny rozdiel vo vlastnostiach medzi STP diesel injector a acetonom cistym.
http://www.youtube.com/watch?v=van5VmJ1yno
http://www.youtube.com/watch?v=oqcaJ4Nr ... re=related
