[b]JAK VYROBIT VYSOCE UČINNÝ VODNÍ OHŘÍVAČ OLEJE (NEREZOVÝ K
Napsal: 31 kvě 2006, 01:38
PODAŘILO SE MI VYROBIT VYSOCE UČINNÝ VODNÍ OHŘÍVAČ OLEJE TAK MOŽNÁ NĚKOMU BUDE INSPIRACÍ A POMUŽE VYŘEŠIT JEHO PROBLÉM.
KOUPIL JSEM NEREZOVÝ INSTALATERSKÝ KRK 4m KDE MI PŘÍMO V PRODEJNĚ NALISOVALI NA KONCE MATICE NA KTERE SE NAMONTUJE REDUKCE NA GUMOVOU HADICI DLE LIBOVOLNEHO PRŮMĚRU.KRK JE VYROBEN Z NAPROSTO TENKÉHO NEREZOVÉHO PLECHU CCA 0,2MM STĚNA.ŽEBROVANÍ KRKU ZARUČUJE JEŠTĚ VELKOU PLOCHU NA PŘENOS TEPLA.
KRK VELMI PEČLIVĚ SVINETE DO SPIRÁLY A TEN PŘIJDE VLOŽIT DO OPLAŠTĚNÍ.
OPLAŠTĚNÍ:ČERNÝ PLECH,VYSTŘIHNOUT DVĚ KOLA O PRŮMĚRU 230MM A MEZI KOLA PO OBVODU NAVAŘIT ŽELEZ.PROUŽEK O ŠÍŘCE 20MM.NEZAPOMENOUT NAVAŘIT DVĚ TRUBKY NA VODU Z TOPENÍ.PRŮMĚR ZVOLIT PODLE VAŠÍ HADICE NA KTEROU SE BUDETE NAPOJOVAT.TRUBKY NAKLONIT DLE VAŠEHO UVÁŽENÍ ABY VODA IDEALNĚ PROUDILA A PŘEDÁVALA TEPLO.
VYŘEZAT PRVNÍ OTVOR NA OBVODOVEM 20MM PROUŽKU OTVOR NA NEREZOVÝ KRK.
DALŠÍ DIRU V DRUHÉM JEŠTĚ NEPŘIVAŘENÉM KOLE PROVRTAT PŘÍMO VE STŘEDU KOLA .VLOŽIT SVINUTÝ KRK A PROVLEST VÝVODY Z OPLÁŠTĚNI.TADY VYVÉST KONEC KRKU.ZAVAŘIT KOLO A ZALETOVAT NEREZOVÉ TRUBKY KRKU.KONEC
PRO CO NEJRYCHLEJŠÍ OHŘÁTÍ OLEJE DO ČERPADLA VLOŽIT DVA KRKY DO JEDNOHO OBALU.JEDEN KRK BUDE ZA FILTREM ABYCHOM NEMUSELI ČEKAT AŽ NAHŘEJEM VELKÉ MNOŽSVÍ OLEJE VE FILTRU.
DRUHÝM KRKEM OHŘÍVAT OLEJ KTERÝ POTEČE DO PALIVOVÉHO FILTRU.
DÉLKA DVOU KRKU JE 2* 4METRY.
ŠÍŘKA OBVODOVÉHO PROUŽKU PRO DVA KRKY JE 35MM.
NAPOJENI VODY PROVÉST PLASTOVYM ( T ) "TÉ" KUSEM POUŽÍVANY VE FIRMACH MONTÁŽÍ PLG CENA JEDNOHO JE 19,-KČ
CENA KRKU ZA METR 119,-KČ
OBAL OHŘÍVAČE JE JEŠTĚ TŘEBA DŮKADNĚ ZAIZOLOVAT I POTRUDI.
NA MATKU KRKU JSEM PŘIDAL ČIDLO DIG. TEPLOMĚRU ZA150,- ABYCH VĚDĚL KDY TEPLOTA PŘEKROČÍ HRANICI 70 STUP.(MAX.HODNOTA TEPLOMĚRU).
VLOŽÍM VÁM I NĚJAKÉ FOTO JEN MI MUSÍTE PORADIT JAK. AHOJ JIRKA
ČLAN.ZATÍM BEZ KOREKCÍ SORRY
