diagnostika na kiu
diagnostika na kiu
potreboval bych zjistit jak se da napichnout kia sportage rok 96. motor 2,0 16V je to pry mazdacky motor.
Nemuzem sehnat ani jestli to nekdo zkousle napinovat na KKL kabel a nebo s jakym programem by to komunikovalo. v Kia servisu maji diagnostiku takovou ze vam napise zpetna vazba... bla bla. a mechanici ani nevi co to znamena - pry to muze byt cokoliv
prohledavam cely internet aj v zahranici,ale nemuzu nic najit.
- uživatel
Bude to vyzerat asi drzo ale aj ja si tu prihrejem svoju polievocku. Kedze u nas tych Ceed a beha furt viac a viac, tak sa pohravam s myslienkov ze rozsirim svoje pole posobnosti aj o koncern Hyundai-KIA. Takze nevyhnutne budem musiet poriesit aj OEM diagnosticky nastroj pre tento koncern. Ked som to pochopil spravne ten GDS by mal byt origo OEM diagnosticky nastroj pre Hyundi-KIA (podobne ako napr. VAS 5054 pre koncern VAG, alebo Examiner SmartHD pre koncern FIAT). Kde sa to da zohnat a coto zhruba obnas po financnej stranke. Takisto ake nutne prislusenstvo (kable, redukcie, adaptery a pod.) su k tomu potrebne?
jmenuje se to Autoboss VCI
Autoboss VCI
Autoboss PC MAX Wireless VCI
Description:
Now you can scan your vehicles anywhere without a cable with Autoboss PC Max Wireless VCI (Vehicle Communication Interface).
Advantage:
Free to test cars within 50-100m. ( Distance depends on environment, the above distance is for reference only.)
Feature:
Covers more than 50 makes, 1000 vehicle systems
Reliable USB connection ensures its stability in complex electromagnetism
Uses most advanced 2.4GHz wireless communication technique
SAE J2534 "pass-thru" ECU reprogramming
Quick test function to diagnose entire vehicle
Main Functions:
Access to powertrain, chassis, body systems
Quick test function to diagnose entire vehicles
Fault code, data stream and service reset
Actuations, adaptations, control model coding
All CANBUS function supported
Internet update function
HYUNDAI immobilizer
Testing report saving function
Volkswagen immobilizer III
Nissan idle self learning function
Multi-languages for international market
Technical Specifications:
Communication distance: about 50~100M
Working frequency: 2.4GHz (global frequency)
Transfer speed: maximally 2Mbps
Power supply: DC12V
Working temperature: -10 ~+70 degree centigrade
Autoboss VCI
Description:
Advantage:
Feature:
Main Functions:
HYUNDAI immobilizer
Power supply: DC12V
