Dálka Jeep
Dálka Jeep
Známýmu přestala jít dálka na centrál je to Cherokee 98 , Diesel. Poradí někdo jak se přizpůsobují ovladače, a nemá někdo schéma centrálu a dálky?
Multivan T5, 2.5tdi 128kw
Octa 2 FL 1.9TDI 77KW
Honda Hornet 600
Honda Hornet 600
Step 1 - The first step is to purchase a blank transponder key. You can purchase these keys from your local Jeep dealer or you can look online for a better deal from a company that sells Jeep parts and Jeep accessories. Once you have purchased a blank Sentry transponder key, bring it to a locksmith to have it cut to match your original key.
Step 2 – Next, insert one of the sentry keys into you ignition. Turn the ignition to the “ON" position for at least 3 seconds, but no longer than 15 seconds.
Step 3 – Next, turn your ignition back to the “OFF" position and replace the first sentry key with the second key. Turn your ignition to the “ON" position again. Make sure the time between switching keys does not exceed 15 seconds.
Step 4 - After about 10 seconds of inserting the second key and turning it the “ON" position, the SKIS indicator light in your instrument cluster will beep once and begin to flash indicating that the system has entered “Customer Learn Programming Mode."
Step 5 - Within a minute of entering the “Customer Learn Programming Mode," turn your ignition switch to the “OFF" position and insert your blank sentry key. Next, turn the ignition back to the “ON" position.
Step 6 - Within 10 seconds of turning your ignition to the “ON" position, you will hear a single beep. Then the SKIS indicator in your instrument panel will stop flashing and stay lit up for 3 seconds, then turn off. This indicates that you have successfully programmed your Sentry Key. You are now ready to start your vehicle with your newly programmed Sentry Key.
________________
Jsme hrdě říci, že jsme nejlepší vývozci kožené bundy v celém světě. Naše značka se stává velmi populární ve velmi krátkém čase, který je "kůže USA". Takže buy online jackets
________________
it does not workchiquillo píše:vyzkoušej opakovaně mačkat tlačítko "UNLOCK" celkem 6 až 8x
a research based studies about Pregnany.its all about Early Signs of pregnancy
