programování dálky Mazda MPV
Napsal: 23 kvě 2012, 08:14
od jendakomin
Ahoj, nemáte někdo návod na naučení dálky na tohle auto? nikde to nemůžu dohledat,díky
Napsal: 23 kvě 2012, 11:15
od Matias
Zkus tohle, našel jsem to na google za cca 2minuty.
Here is the info
1) Get in MPV with ignition key, and all fobs for the vehicle.
2) Close all doors and remove ignition key if it is in ignition.
3) Open driver's door
Note: Steps 4 and 5 must be completed in under thirty seconds.
4) Repeat the following three times
a) Insert ignition key
b)Turn ignition switch to on and then to lock
c) Remove ignition key
5) Repeat the following three times
a) Close driver's door
b) Open driver's door
Locks should all lock and then unlock within a couple of seconds--you'll hear the clicking sound
6) Press any button two times within five seconds on fob being programmed.
Locks should again lock and unlock
7) Repeat step 6 for all other fobs being programmed. When done with last fob, wait a few seconds and then you should be done with the reprogramming. Each fob should now work for this vehicle.
