G4 + BORA 85KW TDI TYP AJM + 6QPREVODOVKA NAJETO 159TIS
G4+BORA 85KW TDI TYP AJM + 6Q PREVOD NAJETO 180TIS
OC 2 77KW TDI TYP BXE +5Q PREVOD NAJETO 55TIS
OC 2 TDI 103 KW TYP BKD + 6Q PREVOD NAJETO 99TIS KM
G5 TDI 103KW TYP BKD +6Q 4X4 PREVODOVKA NAJETO 104TIS KM
OC1 1,8 TURBO TYP AGU NAJETO 180TIS KOMPLET
FABIA 2 HTP 51KW TYP BZG NAJETO 6TIS KM + 5Q PREVODOVKA MAM JEJ 2X
FABIA2 1,9TDI 77KW +5Q PREVOD NAJETO 80TIS KM
VSECHNY MOTORY JSOU KOMPLETNE NASTROJENE NIC NENI SUNDANE !!!
NEJLEPE VSE NA JEDNOU !! TEL 774 37 37 45
POLOOSY
BORY A G4 85KW TDI 6Q PO 1000KC KS
OC2 77KW TDI 5 Q PO 1000KC KS
G5 103 KW 6+ 4X4 2000KC KS
FABIA + ROOMSTER HTP 900KC KS NAJETO MAX 5TIS
OC 1 1,8 TURBO 110KW 5Q 4000 PAR NAJETO 150TIS
AUDI TT 132KW 4X4 4500KC PAR
AUDI TT 132 KW 2 KOLO 4200PAR
AUDI A4 96KW 5Q 1800 PAR
TEHLICE
FABIA HTP PO 750KC KS
FABIA RS PO 1500KC KS
OC1 1,8 TURBO 110KW 3800KC PAR + BRZDY K TOMU
OC 2 77KW TDI 1200KC KS
G5 20TDI 1300KC
OC 1 + G4 PO 800KC KS
TEHLICE JSOU NEPOSKOZENE A MAJI V SOBE CIDLO ABS !
KRTYT MOTORU S NAPISY TDI
OC2 77KW TDI ZA 400KC
G5 77KW TDI 400KC
G5 103KW TDI 400KC
OC 1 TDI 66KW 350KC
OC1 TDI 81KW 350KC
OC 1 PD 350KC
FABIA 1 SDI 400KC
OC 1 1,6 BENZIN 500KC
G4 85KW 350KC
DVERE
OC 1 PREDNI PO 900KC ZADNI 600KC HOLE
OC 2 PREDNI PO 1500KC ZADNI 1000KC CERNA MET NENI NUTNE LAKOVAT
G4 PREDNI 900KC ZADNI 500KC
LEON RV 2001 VIS PREDNI 800 ZADNI 500 KC HOLE
SHARAN DVERE HOLE PO 1100KC
FABIA 1 PREDNI 1000KC ZADNI 500KC
FABIA 2 PREDNI 1300KC ZADNI 950KC
ROOMSTER PREDNI 1300 ZADNI 950KC
AUDI TT 2000KC KS MAM SILVER A CERNE NEMUSI SE LAKOVAT
VSECHNY DVERE JSOU HOLE NEPOSKOZENE
STAHOVACKY
OC1 500 AZ 650KC
FABIA1 600AZ 750KC
FABIA2 PREDNI PO 700KC
LEON RV 2001 VIS PO 600KC
G4 600KC
G5 700AZ 800KC
OC 2 PO 800KC
SHARAN PO 850KC
AUDI TT POUZE PRAVE 1500KC
VSECHNY STAHOVACKY JSOU KOMPLETNI S MOTURKEM
PALUBNI DESKY +AIRBAGY +PASY
OC1 PALUBNI DESKA NOVA ORIG 2800KC
OC1 PALUBKA+AIRBAG SPOLUJEZDCE 4300KC MOZNO PASY 900KC
OC2 PALUBKA+AIRBAGY+PASY 13000KC
G5 PALUBKA+AIRBAGY+PASY 17000KC
SHARAN +ALHAMBRA PALUBKA+AIRBAGY+PASY 9000KC
LEON 2001 VIS 3 RAM AIRBAG PO 1800KC
AUDI ALLROAD PALUBKA+AIRBAGY+PASY 7500KC CERNA BARVA!
AUDI A4 RV 2003 PALUBKA+AIRBAGY 9500KC
PASSAT AIRBAGY+KRYTKA+PASY 5000KC
FABIA2+ROM AIRBAGY 6900KCPASY NEJSOU
CHLADICOVE STENY KOMPLET NASTROJENE POUZE !
G4 STENA+CHLADICE,ZAMEK,VRTULE 5200KC
G4 STENA+CHLADICE,ZAMEK,VRTULE,VYSTUHA 5900KC
OC2 77KW TDI KOMPLET JEN DAT ZPET 7500KC
G5 103KW TDI KOMPLET 8000KC JEN DAT ZPET
VSE ORIGINAL A NEPOSKOZENE
JEN STENA NA G5 77KW TDI 2000KC
TEL 774 37 37 45 DOBIRKA MOZNA . RADEJ VOLEJTE .
AGREGATY TDI ,POLOOSY,AIRBAGY,DVERE,A JINE
