Zdravim menil som panel klimatroniku vypisovalo nakodovanie to som spravil a este mi tam vypisuje
- 9477872 prvni nabeh klimatizacie, B109E - neni provedeno,
aj ked stlacim AC- klima sa nerozbehne ani ledka na tlacitku nezasvieti viete mi poradit co stym spravit?
						yetti vymena climatronic a chyba prvni nabeh klimatiazacie
				IvanHrozny
- Nováček
				leonardino
Re: yetti vymena climatronic a chyba prvni nabeh klimatiazacie
Ahojte,
prosim ako ste vyriesili chybu
524545 - AC Compressor First Run-In
B109E F0 [009] - Not Performed
Confirmed - Tested Since Memory Clear
Mam Superb III, 2.0 TDi/110kW, r.v. 2016.
V pamati zavad klimatizacie VCDS vypisuje chybu (po zmazani sa chyba znovu objavi):
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Info o jednotke:
Address 08: Auto HVAC Labels: 3V0-907-044.CLB
Control Module Part Number: 3V0 907 044 BM HW: 3V0 907 044 BM
Component and/or Version: AC Automat H34 4003
Software Coding: 11010104002110011005000000101002
Work Shop Code: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaPrehVW37X 002014 (SK48)
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 000EB89C9B0302468A-8054
Ked idem vykonat zakladne nastavenie podla tohoto postupu:
http://wiki.ross-tech.com/wiki/index.ph ... limatronic
tak ked vykonam krok "AC Compressor First Run-In" dostanem hned chybu "ERROR: Conditions not correct or request sequence error."
Neviem, aku podmienku nemam splnenu - jedine neviem overit "Load management not active" - ako preverim, ci load management je vypnuty?
Klima normalne isla, ked cez diagnostiku spustim kompresor (kontrola akcnych clenov), tak normalne chladi a kompresor tlaci 24bar.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Info o jednotke:
Toto si skúšal?:
If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change the Runtime (or Driving time) for "compressor run-in" basic setting from 120 -to- 120 and save it followed by repeating the procedure.
				DIAGNOSTIK
Už si to přesně nepamatuji, ale vždy fungovalo tlačítko ECON a zároven vnitřní cirkulace- podržet společně......Určitě , ale pomůže ODIS. Je na to funkce...Tak oprava, je to tlačítko AC a vnitřní cirkulace...
									To je situace!
