serviceMan píše:Tak číslo je 8D0919033A, mají analog. hodiny v otáčkoměru...
Takze 919 - bez can, coz se dalo cekat.
4B0 920 930K maji tento pinout.
Multi-pin connector, 32-pin, blue
Note:
Contacts which are not listed are vacant/unassigned.
1 - → Terminal 15
2 - Brake pad wear
3 - Speedometer output 1
4 - 5 V supply
5 - Fuel gauge sender
6 - Fuel gauge warning OBD 2
7 - Terminal 31 (sensor earth)
8 - Coolant temperature
9 - Terminal 31 (load earth)
10 - Oil pressure (high)
11 - Engine speed signal
12 - Air conditioner shutoff
13 - Electronic throttle/ glow plug indicator
14 - Self-levelling suspension
15 - Terminal 58d
16 - Trailer turn signal
→ 17 - Main beams
18 - Left turn signal
20 - Terminal 58s
21 - Door contact, driver's side
22 - Low coolant level
23 - Terminal 30
24 - Terminal 31 (load earth)
25 - Consumption signal
26 - Right-hand parking light
27 - Left-hand parking light
28 - Speedometer input
29 - Brake fluid low
30 - S contact
31 - Speedometer output 2
32 - ESP/TCS
Multi-pin connector, 32-pin, green
2 - → Transponder
3 - External photo sensor
5 - W wire
6 - Central locking signal
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Standing time output
12 - Terminal 61
13 - Hand brake
14 - CHECK
15 - Oil level/temperature
16 - Oil filter pressure
17 - → Transponder 2
18 - CAN-Bus High (drive train bus)
19 - CAN-Bus Low (drive train bus)
21 - ABS
22 - CAN-Bus High (convenience equipment bus)
23 - CAN-Bus Low (convenience equipment bus)
25 - Bonnet
26 - Fuel filler cap
27 - Belt buckle
28 - K wire
29 - Ambient temperature input
30 - Terminal 58de
31 - Gear selector display
32 - Headlight range control
Multi-pin connector
32-pin, grey
1 - → Menu switch (menu)
2 - Menu switch (out A)
3 - Menu switch (out B)
4 - Menu switch (Enter)
5 - CAN-Bus High (Display)
6 - CAN-Bus Low (Display)
11 - Enable
12 - Clock
13 - Data
14 - Brake light
15 - Washer fluid level
16 - Tail lights / dipped beams (bulb monitor)
17 - On-board computer, left
18 - On-board computer, right
19 - On-board computer Reset
20 - Radio input, auxiliary heater
21 - Summer/Winter setting
22 - Auxiliary heater on
23 - Key branch 1, Navigation system
24 - Key branch 2, Navigation system
25 - Key branch, Telematics
