Stránka 2 z 3
Re: VagTacho USB
Napsal: 30 srp 2006, 13:41
od morose
ThomasVAG píše:Co řikáte na tohle..?
http://www.mtaplus.cz/obchod/index.php? ... rovedeni_2
a co treba tohle???
Product Desc HEX-USB-CAN Interface
Price (in USD): 80.00
Net Weight 0.13 Kg.
Minimum Order Qty. 1 Pcs.
For purchase of Qty 50 or more, special price would be 64.0 USD per unit
Support Brand
Support Phone
Features HEX-USB-CAN Interface compatible with VAG-COM 504.1 (higher versions are not recommended)
Re: VagTacho USB
Napsal: 30 srp 2006, 13:53
od morose
a jeste tohle jsem nasel :) mozna to za tu cenu stoji ne?
VAG Tacho USB Interface
Price (in USD): 90.00
Net Weight 0.12 Kg.
Features Running with latest version 1.5 of VAG Tacho (Do not use 1.6)
Latest update: VW T5/LT bus separate immo box (Temic) ID:VWZ4Z0..
- VDO SEED-KEY protected dashes supported !
(This means: Passat B6, Bora/Jetta to 2004 year, Golf 4 to 2003 year,Skoda Octavia/Fabia to 2004
year , some Seat dashes up to 2002 year ect...)
- VAG Kombiinstrument / Immo box eeprom programmer...by OBD connector!
- Direct USB to OBD Connection! All hardware inside OBD connector!
- Works on any computer that has USB port! No more virtual COM Ports!
- This is a TRUE USB connection! Windows XP compatible software!
- Audi A4,A6,A8 separate immo box 1994-1999 read PIN code,and read/write eeprom!
- Audi A3,A4,A6,TT, New Beetle Magnetti Marelli M73 (1998-2002 year) read PIN code / change mileage!
- New Beetle Magnetti Marelli M73 (2001 to 2005 year) read PIN code
- Almost all VDO dashes for VW/Seat/Skoda up to year 2004 read/write eeprom!
- Almost all VDO dashes for Audi up to year 2001 read/write eeprom!
- Almost all MotoMeter dashes for VW/Seat up to year 2001 read/write eeprom!
- Automatic functions: Repair dashboard, Read PIN code !
- All this by using car OBD connector! Without disassembly dash or immo box from car!
Napsal: 30 srp 2006, 14:51
od mira
a kolik bude stat postovny pro ten jeden kus vis? a clo a DPH?
Napsal: 30 srp 2006, 15:15
od morose
mira píše:a kolik bude stat postovny pro ten jeden kus vis? a clo a DPH?
vím - airmal 16USD, DHL 59USD...clu a dph nepodléhá 8)
Napsal: 30 srp 2006, 22:08
od maniacdewil
no nevim ja bych do toho asi nešel,aby ti pak nepřišel kus dratu na kterym se pak mužeš oběsit to si ho mužeš koupit tady http://www.viaken.pl/sklep.php?lang=pl&kat=2&prodid=84 a nemaš to zas tak daleko ,ja tam kupoval KWP a fachčí a je to skoro za stejny prachy .Vag-tacho jsem kupoval na motordiagu i s hex-can po slevě,kamoš mi vratil DPH tak mě oba vyšli na 9tis (noteeth)
Napsal: 31 srp 2006, 00:24
od morose
maniacdewil píše:no nevim ja bych do toho asi nešel,aby ti pak nepřišel kus dratu na kterym se pak mužeš oběsit to si ho mužeš koupit tady http://www.viaken.pl/sklep.php?lang=pl&kat=2&prodid=84 a nemaš to zas tak daleko ,ja tam kupoval KWP a fachčí a je to skoro za stejny prachy .Vag-tacho jsem kupoval na motordiagu i s hex-can po slevě,kamoš mi vratil DPH tak mě oba vyšli na 9tis (noteeth)
Kluci ja to objednal....dám vedet jestli jsem koupil blbost nebo ne. Ale bojim se celkem dost... :?
Napsal: 31 srp 2006, 10:55
od lake
ja si myslim, ze stale riesite tu istu somarinu.
vagtacho nie je taky drahy ako vagprog,alebo supervag -pri tychto kabloch by som riesil ako ich zohnat lacnejsie, ale original vagtacho aj s updatami stoji par korun a mate garanciu podpory....mozno je to o 2-3000 drahsie ako klony.
nechapem preco takto riesite otazku nakupu tohoto kabla.
klon:
1. verzie slapu len do v1.62 vacsinou
2. kupite to od kadekoho (nemyslim obchody typu motordiag,MTAplus a pod) a ked sa to poserie ste nahrati.
Za tu dobu, co sa tu riesia otazky kde nakupit a ako lacnejsie zohnat ste uz s originalom mohli zarobit par koruniek ;)
Napsal: 01 zář 2006, 21:07
od maniacdewil
v tomhle ti davam za pravdu ,možna sem ho měl koupit origo ,ty up-daty budiku by se šikly ale co mam dělat s tim klonem :-D
až ho prodam tak do s tebou do origo
PRODAM TYDEN STARY KABEL VAG-TACHO ZA 5999.- (noteeth)
Napsal: 03 zář 2006, 18:35
od ghoust
nemate nekdo napln do 93c46 ky ? bo kamos si ho updatem zabil
Napsal: 04 zář 2006, 12:20
od jaroSK
myslis ze to zachrani napln do 93c46 ??? :o :o :o
a co napln do mcu Atmel ???
Napsal: 04 zář 2006, 17:14
od ghoust
no chcu to aspon skusit bo se to hlasi jen jako ciste ftdi
Napsal: 04 zář 2006, 22:10
od lake
mam to na vymenu, aj kwp2000+ a kopu inych veci.. ;)
Napsal: 05 zář 2006, 01:04
od Saly
Kto to potrebuje mam za 150eur. Fachci 100%. Mam to odskusane. Posli sukromnu spravu. :)
Napsal: 05 zář 2006, 07:30
od mario313
To ghoust
Jasne, ze staci prepisat v programatore 93C46.
Napis mi mail kam Ti poslem *.bin.
Maros
Napsal: 05 zář 2006, 18:28
od mario313
To Ghoust:
Mas to tam, skor som nemal cas...sorry
