Seat Altea 1.9 TDi 77KW 2007 BXE vypis zavad
VW/Audi/Škoda/Seat
andre441
Příspěvek od andre441 »
Zdravim pani.
Chcem Vas poprosit o mensie vysvetlenie mojich zavad na aute.
Friday,26,September,2014,17:28:38:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ5PZ7R047381 License Plate:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LN HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9246
Revision: --H06--- Serial number: SEZ7Z0G3708345
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 117219 km
Time Indication: 0
Date: 2000.00.00
Time: 10:14:58
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00101100
Temperature: 72.0°C
Bin. Bits: 01010000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06402 785 00200
VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 B
Component: ClimatronicPQ35 010 0502
Shop #: WSC 00000 000 00000
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004532622
Coding: E9880F2700041000431E00000000000000017F0B5C4000
VCID: 6CD7223B4F7E2C7E58B-8039
Subsystem 1 - Part No: 5P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 161206 022 0601
Coding: 00056208
Shop #: WSC 06402
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH04 0090
Coding: 00137517
Shop #: WSC 06402
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 117219 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: S7 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0XU8UL
Coding: 0021303
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Serial number: 6332MSME155C7C7DX
Subsystem 2 - Serial number: 6342MSME15147B0FG
Subsystem 3 - Serial number: 6351HSME0C3B51616
Subsystem 4 - Serial number: 6361HSME0C367003%
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002042
VCID: 8109E38FD8FC51161BD-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106C01051D
Coding: 3D3F034007008202
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 117219 km
Time Indication: 0
Date: 2000.00.00
Time: 10:11:21
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No: 5P0 920 823 C
Component: IMMO VO3 0422
Shop #: WSC 28924 401 89640
VCID: 306FF64BA3D6889E243-8065
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000605569119
Coding: 0000176
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 88
Reset counter: 42
Mileage: 101197 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.077 H07 1806
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
Freeze Frame:
Mileage: 117210 km
Temperature: 22.0°C
Voltage: 12.50 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 818000005183CC7F0006050560084F01207C80
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000034769116
Coding: 0000176
VCID: 3C77D27B7F9E7CFE88B-8069
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 186 B
Component: Radio BVX 0006
Coding: 0040484
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 M HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1114
Revision: 11006001 Serial number: 00000001006649
Coding: 0000144
VCID: 3A7BD46375AA42CE9A7-806F
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 M HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1114
Revision: 11006001 Serial number: 00000001023241
Coding: 0000144
End ---------------------------------------------------------------------
[/list]
Patooo
Příspěvek od Patooo »
mas zly zhavic na tretom valci.. a ostatne zavady vymaz a po case to napoj co znova vypise
andre441
O tom zhavici viem.Dik.
Minule mi chlapik robil diagnostiku.Zaroven teply start softwerovo.Chystam sa na rozvody buduci tyzden.Mam ich dokonca posunute do minusu -3,4.Chalan vravel ze mam dost chyb na diagnostike,tak ich vymazal.Skoda ze som si ich neodlozil.Dnes som si robil sam diagnostiku.A toto mi vyplulo.Skusim vymazat.A uvidim.
Trapi ma chyba:
Vyskytuje sa tam dost casto.
Skusim vymazat.[/b]
Patooo
a vsetko ti ide tak ako ma ?
andre441
Ano vsetko ide, tak ako ma.Nic mi nevypisuje,na palubnej doske.
Ale aj tak by ma zaujimalo co to moze znamenat.
