passat b6 DSG po zohriati neradi
mtapaj
Příspěvek od mtapaj »
Pri studenom motore vsetko funguje no po zohriati na prevadzkovu teplotu prestane radit prevodovka nejde ani spiatocka ide iba jednotka.
Diag. 18154 p1746
neaky tip na opravu??
KTS 530 k dispozicii
Rayx
Příspěvek od Rayx »
http://wiki.ross-tech.com/wiki/index.ph ... 746/005958
Supply voltage for solenoid valve electrical fault in circuit
Possible causes:
Cable interruption or short circuit with plus of contacts 52, 53, 54 or 55 of control module (J217)
Control module (J217) defective
Possible solutions:
Read measuring block
Check supply voltage for gearbox control module (J217)
Check / repair wiring and connections
Perform electrical check
Extra information:
First plug connections for contact corrosion or. Check penetrated moisture and replace if necessary. if faults in the solenoid valve pin are displayed, pay special attention to the 16-pin plug connection at the gearbox between the control box and the cable strand of the vehicle
mtapaj
prekontroloval som napajanie ok pri skusobnej jazde prevodovka zohriata na 65 stupnov prevodovka v nudzaku isla iba na trojku pri spomaleni preradi na jednotku po vytoceni na cca 450otmin preradi na trojku a ide iba na trojke pri uplnom spomaleni zaradi jednotku
zavada 17150 p0766 solenoid 4 N91
Ked som dosiel do dielne uz bola zavada 18154 p1746
Skusim N91 vymenit.
